Swiftech Apogee XT Extreme CPU Waterblock Review
Looking Closer at the Copper Block
Swiftech Apogee XT
With the Apogee XT free of the packing we can get a better look at it. The top half of the block is CNC machined brass and plated with a black chrome finish. This is a change from the GTZ design that was machined out of Delrin, a durable and strong plastic.
Swiftech Apogee XT
Another change is the inlet port can be moved to allow room for compression fittings to be installed. In its stock location (shown) the inlet and outlet ports are too close for some compression fittings to be installed. More on this when we take the block apart.
Swiftech Apogee XT
The base of the Apogee GTZ i7 is also CNC machined, but out of C110 copper. The base is also lapped and polished to a mirror finish.
Swiftech Apogee XT
Like I had mentioned earlier, the top plate for the Apogee XT is able to be used across all the LGA Intel sockets. This is done with a slot that allows for the pins to adjust to fit each socket.
Inside the Apogee XT
To take the block apart you have to remove the top plate. This is done by removing the 6 allen head screws, 3 either side of the block.
Swiftech Apogee XT
With the bottom removed we can see the inside bottom of the top. The inlet port is in line with the hole you see in the center of the block. This is centered on the CPU. The coolant then flows outward from the center, through the micro pin matrix and eventually out the outlet port.
Swiftech Apogee XT
Flipping the top over, we can take another look at the inlet port.
Swiftech Apogee XT
With the inlet port cover removed we can see the seal and the small water channel that allows for the port orientation to be changed. Doing this, Swiftech says, will affect the flow of the block and ultimately the performance.
Swiftech Apogee XT
However, if you need the space for the fittings then its nice to have the option, but you, the end user, will have to decide if the performance hit is worth it.
Swiftech Apogee XT
Here we have the bottom of the Apogee XT. The heart of the Apogee XT is the pin matrix design. The 0.009 micro pin matrix is the heart of the Apogee GTZ i7. For a little scale, normal 20lb copy paper is 0.0038 thick.
