Spire TherMax Pro CPU Cooler Review
Inside the box
Spire Thermax Pro CPU Cooler Retail Box
There is nothing too much out of the ordinary here. The cooler is packaged in a blister pack that is inserted into a cardboard outer container so that the cooler and fan are on display. Upon removing the packaging you will see that the fan and cooler have not yet been mounted together. Also, in the bottom of the packaging you will find the included parts pack that allows you to use the cooler on any modern processor.
A quick look inside the pack shows the different mounts as well as your options for how to get the electricity pumping into your new Spire TherMax Pro cooler. You have the option of using the three pin motherboard connector that is attached to the fan or you also have the option of using the four pin Molex adapter.
They have also included a rear slot mounting fan speed controller. Use this controller with caution, as I used the fan controller provided with my heatsink and cooler and it does not work at all. So I almost lost my CPU and motherboard to the gods of overheating. Luckily my motherboard works correctly and it shut down the system when it got too hot.
