Silverstone Strider Essential & Strider Plus 500W Power Supply Review
ST50F-ES and ST50F-P Review Introduction
Silverstone has been in the power supply market for quite some time now and it is a renowned manufacturer among advanced users and enthusiasts. If there is a thing that makes Silverstone standing out from other manufacturers is that it is one of the very few companies which has such a long products line-up and offers both pinnacle-level and budget-level products. Today we will be having a look at two 500W units, one from the Strider Essential series and one from the Strider Plus series. As the name suggests, the Strider Essential series is the most basic series which Silverstone currently offers, while the Strider Plus series is a step higher up the performance ladder and features a fully modular design.
At the time of this review, Silverstone retails the 500W version of the Strider Essential for just $39.99 incl. shipping (after rebate), while the corresponding version of the Strider Plus series currently retails for $74.99 incl. shipping; therefore, in this review we will be seeing both what $40 can get you and if the upgraded modular Plus version is worth the nearly double retail price.
Silverstone Strider Essential ST50F-ES 500W specifications
  • High efficiency with 80 PLUS
  • certification
  • 500W 24hour continuous power output with 40operating temperature
  • Class-leading single +12V rail with 34A
  • Multiple protection circuitry
  • Silent running 120mm fan with 18dBA minimum
  • PCI-E 8pin and PCI-E 6pin connectors support
  • Support ATX 12V 2.3
  • Active PFC
Model No.
SST-ST50F-ES
Max. DC Output
500W
Load Range
+3.3V
+5V
+12V1
+12V2
+12V3
+12V4
+5VSB
-12V
Max.(Amps)
24A
20A
34A
2.5A
0.3A
Peak (Amps)
Min.(Amps)
0.1A
0.2A
0.6A
0A
0A
Range (%)
5%
5%
5%
5%
10%
Line Reg.(%)
1%
1%
1%
1%
1%
Ripple(mVp-p)
100mV
100mV
150mV
100mV
150mV
combined +3.3, +5V
120W
combined +12V
408W/34A
Input Voltage
103.5V~253V
Input Frequency Range
47Hz ~ 63Hz
PFC
Active PFC�PF>0.95 at Full Load�
Efficiency
>80% at 20%~100% loading
MTBF
100,000 hours at 25�at Full Load�
Operating temperature
0C ~ 40C
Protection
Over Current Protection
Over Power Protection
Over Voltage Protection
Under voltage protection
Short Circuit Protection
Silverstone Strider Plus ST50F-P 500W specifications
  • 24hour continuous power output with 40operating temperature
  • 100% modular cables
  • Efficiency 82%~85% at 20%~100% loading
  • PCI-E connectors support
  • Support ATX 12V 2.3 & EPS 12V
  • Active PFC
Model No.
SST-ST50F-P
Max. DC Output
500W
Load Range
+3.3V
+5V
+12V1
+12V2
+12V3
+12V4
+5VSB
-12V
-5V
Max.(Amps)
24A
20A
34A
2.5A
0.3A
Peak (Amps)
Min.(Amps)
0.5A
0.3A
0.5A
0A
0A
Range (%)
5%
5%
5%
5%
10%
Line Reg.(%)
1%
1%
1%
1%
1%
Ripple(mVp-p)
50mV
50mV
120mV
50mV
120mV
combined +3.3, +5V
120W
combined +12V
408W/34A
Input Voltage
90V~264V
47Hz~63Hz
PFC
Active PFC�PF>0.95 at full load�
Efficiency
82%~85% at 20% ~ 100% loading
MTBF
100,000 hours at 25C, full load
0C ~ 40C
Protection
Over current protection
Over power protection
Over voltage protection
Short circuit protection
