Seagate 500GB SSHD Thin Hybrid Drive Review
Comparison Drives & Test System
Legit Reviews Storage Benchmark Test System
All tests were performed on a fresh and up-to-date install of Windows 8 Pro x64 with no other applications running while using AHCI mode set through the BIOS. Synthetic Benchmarks were run with the OS loaded on a 120GB Corsair Force SSD. All components were set to their default speeds and are listed below.
LR Z77 Test Bench
Z77 Legit Reviews Test Bench
Intel LGA 1155 Test Platform
Component Brand/Model Live Pricing
Processor
Core i5 2500k
Motherboard
ASUS Maximus V Gene Z77
Memory
Kingston HyperX KHX16C9B1RK28 8GB
OS Drive
Corsair Force 120GB (FW 2.4)
Power Supply
Antec Basiq BP550W Plus-EC
Operating System
Windows 8 Pro 64-Bit
For comparison, we used the previous generation hybrid Momentus XT 750GB drive we first tested at the end of 2011.
CrystalDiskMark 5.2.0 Readout:
For the Seagate 500GB SSHD, the readout on CrystalDiskInfo 5.2.0 shows that both NCQ and S.M.A.R.T. are enabled and the interface is confirmed at SATA III (6Gbps) with the disk speed at 5400RPM. The firmware version used for testing is the latest available at this time – SM11.
CRYSTALDISKINFO
Let’s look at some benchmarks.
