Intel NUC NUC5i5RYK Running HyperX Impact 1600MHz and 1866MHz Memory Review
1866MHz Memory In The Intel NUC NUC5i5RYK
NUC-MEM
After swapping out the 1600MHz modules with the 1866MHz modules we were up and running in seconds. The Intel NUC NUC5i5RYK UEFI/BIOS allows you to manually adjust the memory, so we figured we’d give it a shot. We tried lowering the CAS Latency down to 9 from 10 and the system failed to post. After having to recover the UEFI/BIOS by removing the jumper on the board we tried overclocking the kit by increasing the memory multiplier and again found the NUC failed to post. After another successful UEFI/BIOS recovery we found ourselves happy with the default SPD settings of 1866MHz with 10-10-10-32 1T timings.
1866
We ran a handful of benchmarks on the Intel NUC NUC5i5RYK and rather than making a chart for each specific test scenario we simply placed them into the table below. We ran Cinebench R15, 7-zip, 3DMark Sky Diver, PCMark 8, Sandra 2015 Memory Bandwidth and AIDA 64. It should come as a shock to anyone, but we saw performance improvements in all of the benchmark tests with the faster memory!
Intel NUC5i5RYK 1600MHz 1866MHz % Difference
Cinebench OpenGL 31.80 fps 36.63 fps +15.2%
Cinebench CPU Multi 259 cb 263 cb +1.5%
Cinebench CPU Single 107 cb 110 cb +2.8%
7-Zip 7350 MIPS 7389 MIPS +0.5%
3DMark Sky Diver 3634 pts 3955 pts +8.8%
PCMark 8 3173 pts 3273 pts +3.2%
Sandra Memory Bandwidth 16.10 GB/s 20.68 GB/s +28.4%
AIDA64 Memory Read 20407 MB/s 23445 MB/s +14.9%
AIDA64 Memory Write 22943 MB/s 28597 MB/s +24.6%
AIDA64 Memory Copy 20118 MB/s 25070 MB/s +24.6%
AIDA64 Memory Latency 70.8 ns 68.9 ns +2.7%
The greatest improvement was 28.4% and that came in the Sandra Memory Bandwidth benchmark test where we found the memory bandwidth of our system went from 16.10 GB/s to 20.68 GB/s! The smallest performance gain came in 7-zip where there was just the workload improved by just half a percent. One of the areas that saw the most improvement was in the graphics tests, so we figured we’d look closer at a couple real game titles.
Let’s take a look at them on the next page
