ID-Cooling RGB Trio Triple Fan Value Kit Announced
ID-Cooling RGB Trio Offers Brilliant Effects For Users On A Budget
If you’ve been wanting jump aboard the RGB train and outfit your system with some RGB fans, only to be scared off by the high cost of some of the offerings, ID-Cooling may have a solution for you. The ID-COOLING DF-12025-RGB-TRIO is a $45 USD MSRP 120MM Triple Fan Kit that features a remote control and compatibility with Asrock RGB Sync, Asus Aura Sync, Gigabyte RGB Fusion and MSI Mystic Light. For users who don’t want to use motherboard-based software or who are using systems without a motherboard RGB header, the ID-COOLING RGB Trio kit and the included remote are capable of 20 static colors and 22 dynamic colors that include effects like blinking and breathing modes.
The ID-COOLING DF-12025-RGB-TRIO are outfitted with nine LED’s in the fans hub and the fan blades feature a diffuse material that will allow for bright, even lighting. ID-Cooling has specified the RGB Trio 120mm fan kit to operate in the 900-2000 RPM range at 16~31.5dB noise levels, producing a maximum airflow of 56.5 CFM. Accessories included with the ID-Cooling RGB Trio fan kit include mounting screws, an RGB splitter, remote control and receiver, fan power splitter and a male-male RGB splitter adapter.
With a nice amount of lighting effects at their disposal and decent specs for airflow and noise, the ID-COOLING 120mm RGB Trio fan kit look to be a capable entry into the RGB fan market, was has seen no shortage of products over the past year. Only time will tell how the fans stack up against others, but with quality RGB fans from some manufacturers costing over $30, a kit that puts the fans at under $15 each is certainly going to be a welcome entry into the market if they pass the quality test.
For more information on the ID-Cooling DF-12025-RGB-TRIO, check out the product page here.
