ECS PN1 SLI2 Extreme Motherboard Review
Hd Tach 3
Hd Tach 3
HD Tach will test the sequential
read, random access and interface burst speeds of your attached storage
device (hard drive, flash drive, removable drive, etc). All drive
technologies such as SCSI, IDE/ATA, 1394, USB, SATA and RAID are
supported. Test results from HD Tach can be used to confirm
manufacturer specs, analyze your system for proper performance, and
compare your performance with others. HD Tach is very easy to use,
quick, and presents data in easy to read graphs, including the ability
to compare two storage devices on screen at the same time for easy
analysis.
foxconn 975x review
foxconn 975x review
Burst speeds are coming in higher on the ECS board that they do on the Foxconn, overall though, the average read speeds are identical on the boards.
