Corsair Hydro Series H100 CPU Water Cooling Kit Review
Unboxing the Corsair H100
Corsair Hydro Series H100 box plastic
The H100 arrives in plastic wrap, so you will know that you are the first to open it.
Corsair Hydro Series H100 box art
The box is done in usual Corsair styling. There is a nice image of the new pump housing.
Corsair Hydro Series H100 box end
One end has only the simple H100 logo and a small, overall image of the kit.
Corsair Hydro Series H100 box end specs
On the opposite end are the specifications of the H100.
Corsair Hydro Series H100 box side cosair link
On the side are images of the cooler and some text about the Corsair Link in multiple languages.
Corsair Hydro Series H100 box side contents
On the opposite side is a list of the box contents in multiple languages.
Corsair Hydro Series H100 box side features
On the back of the box is list of features in multiple languages and a small temp chart.
Corsair Hydro Series H100 box chart
The chart shows how the H100 compared to the stock Intel HSF as well as the H60 and H80. According to the chart the H100 is a significant improvement over the H60 and has a slight gain over the H80.
Corsair Hydro Series H100 opening box
Upon first opening the box you see the instructions and a layer of sheet foam.
Corsair Hydro Series H100 packing
Under the sheet foam is the kit will all the individual parts wrapped in plastic and held snugly in a cardboard tray.
