Corsair CS450M Power Supply Review
Corsair CS450M Power Supply Review Introduction
Corsair has been a very active player in the PSU market the past year, announcing release after release, bringing several new power supply units into the market. A few weeks ago, the company has announced the release of the CS-M power supply series, a series designed for basic and midrange PCs, bringing the number of the power-related products that they offer even higher. Even though the series is designed with value in mind, Corsair claims features and performance that would significantly outperform their previous mainstream series, the TX. Today we are having a close look at the CS450M, which, as the name implies, is the 450 W version and the least powerful unit of the series.
From the table below, we can see that the 450 W version has an MSRP of $89.99 and can be found online for $89.99 shipped. Although we cannot compare that directly to the older TX series, as the least powerful TX series unit is a 650W version, the TX650M has an MSRP of $129.99 and the CS650M an MSRP of $109.99. This means that the new CS series not only is cheaper by $20 but it also is 80Plus Gold certified, a leap forward than the TX series which only meets 80Plus Bronze standards. What about the rest of its performance aspects though? We will find out in this review.
Corsair CS Series Models
Street Price
CS450M
$89.99
CS550M
$99.99
CS650M
$109.99
CS750M
$119.99
Corsair CS450M
Corsair CS450M Power Supply Features
  • The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
  • 4th generation Intel Core processor Ready (Intel Haswell and Z87 motherboards)
  • 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions
  • Modular cables allow you to remove unneeded cables.
  • The low-profile, flat modular cable design reduces air friction and helps maximize airflow through your computers chassis.
  • A three year warranty and lifetime access to Corsairs legendary technical support and customer service
  • Active Power Factor Correction (PFC) with PF value of 0.99.
  • Universal AC input from 100~240V
  • Multi-GPU Ready
  • Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components
  • Safety and Agency Approvals: FCC, ICES, UL, CUL, TUV, CCC, CE, RCM, CB, EAC, KC, BSMI, ROHS, WEEE
Corsair CS450M PSU Specifications
Warranty
Three years
Dimension
150mm x 86mm x 140mm
Modular
Yes
Power
450 Watts
80 Plus
Gold
ATX Connector
1
EPS Connector
1
PCI-E Connector
1
4 Pin Peripheral Connector
3
SATA Connector
4
Floppy Connector
1
MTBF
150,000 hours
