Corsair Announces Air Series LED High Airflow PC Case Fans
Corsair Lights Up Air Series Fans with New AF140 LED and AF120 LED Models
Fremont, California October 1, 2013 Corsair, a worldwide designer and supplier of high-performance components to the PC hardware market, today announced the immediate availability of the Air Series AF120 LED Quiet Edition and Air Series AF140 LED Quiet Edition high airflow PC case fans. The new fans are the only LED fans to use Corsairs award-winning AF series impeller designs to produce higher airflow at lower noise levels. The Air Series LED fans are available in 120mm and 140mm sizes with red, white, blue, or purple LED lighting.
The Air Series LED Quiet Edition high airflow PC case fans are designed with custom-molded, ultra-thin, clear frosted blades with a sleeved bearing system and four vivid LEDs. The result is a visually striking fan which helps users build great looking PCs while delivering outstanding cooling with exceptionally low vibration, noise and turbulence. The fans are ideal for mounting at the rear or top of PC cases to exhaust heat from a PCs CPU, graphics accelerators, and other heat generating components. The Air Series LED fans work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
Users often feel they are sacrificing quality when using LED fans, said Xavier Lauwaert, Director of Product Marketing at Corsair. Our new Air Series LED fans combine the proven low-noise, high-performance design of our standard Air Series fans with just the right amount of LED visual flair. Now users can enhance and customize the look of their PCs with LED fans without compromising performance.
Air Series Specifications
Size
140mm x 25mm
125mm x 25mm
Airflow (at 12V)
66.4 CFM
52.19
Speed (at 12V)
1200 RPM
1500 RPM
Sound level (at 12V)
25.5 dBA
25.2 dBA
Static pressure (at 12V)
0.80mm / H2O
0.75mm / H2O
Power usage
0.23 A
0.4 A
Connector cable
3-pin
3-pin
Pricing, Availability, and Warranty
The Air Series LED high airflow PC case fans are available immediately from Corsair’s worldwide network of authorized distributors and resellers. They are backed with a limited 2-year warranty and Corsairs excellent customer service and technical support.
Models and suggested prices are as follows:
Model
Part Number
MSRP (US)
Air Series AF140 LED Red Quiet Edition
CO-9050017-RLED
$15.99
Air Series AF140 LED White Quiet Edition
CO-9050017-WLED
$15.99
Air Series AF140 LED Blue Quiet Edition
CO-9050017-BLED
$15.99
Air Series AF140 LED Purple Quiet Edition
CO-9050017-PLED
$15.99
Air Series AF120 LED Red Quiet Edition
CO-9050015-RLED
$12.99
Air Series AF120 LED White Quiet Edition
CO-9050015-WLED
$12.99
Air Series AF120 LED Blue Quiet Edition
CO-9050015-BLED
$12.99
Air Series AF120 LED Purple Quiet Edition
CO-9050015-PLED
$12.99
Air Series AF120 LED Red Quiet Edition Twin Pack
CO-9050016-RLED
$23.99
Air Series AF120 LED White Quiet Edition Twin Pack
CO-9050016-WLED
$23.99
Air Series AF120 LED Blue Quiet Edition Twin Pack
CO-9050016-BLED
$23.99
Air Series AF120 LED Purple Quiet Edition Twin Pack
CO-9050016-PLED
$23.99
To learn more about Corsair fans, please visit: http://www.corsair.com/cpu-cooling-kits/air-series-fans.html
About Corsair
Founded in 1994, Corsair supplies high performance products purchased primarily by PC gaming enthusiasts who build their own PCs or buy pre-assembled customized systems. The company’s award-winning products include DDR3 memory upgrades, USB flash drives, power supply units, solid-state drives, PC speakers, gaming headsets, gaming keyboards, laser gaming mice, system monitoring and control devices, PC cooling products, and computer cases.
