Cooler Master GeminII CPU Cooler Review
Introducing the GeminII CPU Cooler
Heatpipe tower coolers are nothing new, but the trend has coolers getting taller and having larger fins. Cooler Master has gone a different route with the GeminII. With their new heatpipe cooler they went short and wide, real wide, so much so that they have called it a CPU AND a Board cooler. The GeminII can also be used as a passive or active cooler as the end user has the option to install twin 120mm fans on to the GeminII. Lets look at the specifications and features.
Features
  • CPU+Board Cooler Design cools CPU and its surrounding components.
  • Compatible with AMD X2 Dual Core, Intel Core 2 Duo and Core 2 Extreme.
  • Complete cooling solution cools CPU and its surrounding components (motherboard, memory, VRM, chipset and VGA cards).
  • Fan bracket design for mounting two 120 mm fan cools mainboard.
  • Flexible bracket design provides interference-free installation
  • Copper base with 6 heat pipes design creates superior cooling performance
  • Huge aluminum fin design for excellent heat dissipation.
Specifications
  • CPU Socket: Socket AM2/754/939/940/LGA775
  • Dimensions: 175×124.6×81.5mm
  • Weight: 847g
  • Material: Copper Base/ 6 Heatpipes/ Aluminum Fin
  • Thermal Resistance: 0.17C/W (with Cooler Master fan R4-S2S-12AK-GP or R4-S2b-12AK-GP)
  • Noise: 20.7 dBA (with Cooler Master fan R4-S2S-12AK-GP or R4-S2b-12AK-GP)
CPU Support
Cooler Master GeminII CPU Support Chart
