2GB Kingston ultra low-latency 1375MHz CL5 DDR3 Memory Review
The Test System
The Test System
Testing Procedure:
All testing was done on a fresh install of Windows XP Professional build 2600 with Service Pack 2 and DirectX 9.0c. All benchmarks were completed on the desktop with no other software programs running. All of the modules were run in dual channel mode with a 120mm fan placed on top of them to keep them cool! The XFX GeForce 8800 GTX used ForceWare 158.22 video card drivers and the ASUS P5K3 motherboard was updated from BIOS version 0405 that was used in our last DDR3 article to BIOS version 0604 by using ASUS flash. This BIOS update did impact the performance numbers, so if you own this motherboard you will want to update to the latest BIOS.
Memory Settings:
- Corsair XMS3 DHX – 9-9-9-24 1T @ 1333MHz
- Kingston HyperX LL – 7-7-7-20 1T @ 1375MHz
- Kingston HyperX UL – 5-7-5-15 1T @ 1375MHz
- OCZ Platinum – 7-7-7-20 1T @ 1333MHz
- Super Talent – 8-8-8-18 2T* @ 1333MHz (This kit is unable to run 1T CMD)
Here is the Intel P35 Express DDR3 Test platform:
| DDR3 Test Platform | |||||
| Component | Brand/Model | Live Pricing | |||
| Processor | Intel Core 2 Duo E6750 | ||||
| Motherboard | ASUS P5K3 Deluxe
| Memory | 2GB Kingston HyperX PC3-11000
| Video Card | XFX GeForce 8800 GTX | ||||
| Hard Drive | Western Digital RaptorX | ||||
| Cooling | Intel Retail Box | ||||
| Power Supply | Thermaltake 850W | ||||
| Operating System | Windows XP Professional | ||||
